- Mon Jun 24, 2013 4:05 pm
#26110
Simon - I think that when it comes to these matters, you must be one of the most knowledgable people on this forum... after fitting the gearbox stiffener recently I had to replace the spring clip for the foot lever - now I'm experiencing clutch slip mainly in 3rd and 4th gear. So I am back to the clutch adjuster for fine tuning (opening up the primary and checking trueness of all components is something I will also have to do, I know) and I note your comments regarding your 1st reply to Bighazz... when I put the bike in 1st gear with the clutch in, the kickstart moves the bike forward when operated, so more clearance is required? Does this mean I need to slacken the adjuster nut off? many thanks,
Peter.
