- Mon Nov 19, 2012 9:40 am
#19723
Jacob,
Glad you found a way to get it started. My only point was that opening the throttle effecftively renders the fuel enrichener useless because air will be drawn to the motor by the path of least resistance ie thru the carb main boby and bypassing the cold start system.
Again forgive me if I'm telling you stuff you already know but please don't draw conclusions from your past experiences with mark 1's when it comes to cold starting they work in very different ways. Does your MK2 have a cable or lever for cold starting? If it's a cable it works in the opposite way to a MK1 ie pull on the cable to activate.
When you've got the motor running and the cold start system in use you should have a fast tick over (even racing) without touching the throtle if not you should suspect a fault or using it the wrong way round.
