- Fri Sep 14, 2012 11:45 am
#1154
Hi All,
I have a 2001 Enfield Bullet 350 Export model which I recently purchased. When going up hill I had noticed the clutch was slipping and on inspection of the cable as well as being routed incorrectly (it lays across the barrel) there was no slack whatsoever in the cable at the ends or centre adjuster. As I have Minda controls without adjusters fitted I checked which cable I should be using by looking on here and fitted a new OE replacement which came with the bike which had the correct part number however I have exactly the same problem as before, no slack.
So I have several questions.
Is there a way of identifying what type of handlebar controls should be on my enfield? I am starting to wonder if perhaps the reason for my problems is that my Minda clutch lever perhaps should have a screw in adjuster and cable to suit?
Should the non adjuster Minda cable 145408 still fit my Minda lever with the adjusters removed?
Does anyone know where I can buy adjusters for the Minda controls if they should be fitted?
I would be very grateful for any assistance please.
Cheers
Cheers
