- Fri Jun 29, 2012 12:05 pm
#14150
From the mechanism as I understand it I can't see much point in backing the adjustment screw off. Surely all that will happen is that as soon as you start taking up the slack in the cable the actuating arm will be pulled and the screw clearance will be taken up anyway, so you will be back at square one. In which case the arm will have moved through some of it's travel leaving less available when the lever is pulled. It might therefore make things worse.
