#523
Hi guys & gals ----------- had a bad day fettling the Bullet??, nothing going the way it should??, forgotten WHY you ever got into this in the first place ?? Then read this}--------------http://en.wikipedia.org/wiki/Easy_Rider ... -------And play this}---------http://www.youtube.com/watch?v=qCEeg6-a ... -------Not such a bad day after all, is it ?? Don't worry, I also find that bus pass useful-------- Oh well !!!!
#12987
alan,you know you,ll get there in the end ,look at me the only guy capable of demolishing a main bearing in the chinese diesel not that the engine had stopped working just developed a small rattle at the back of the flywheel!!so the primary case came off for the third time in as many weeks engine stripped bearing fitted £15 for bearing up and running after a complete strip,you know it takes DEDICATION DEDICATION THATS WHAT YOU NEED and on that note its goodnight from roy castle oi put that fag out!!!!!
#12989
-----------Hi matey !! Strange effects those diesel fumes have on a person ?? When I was working----no, sorry, I meant "Employed" on British Railways as a diesel loco Technician we used heavy duty string as laces because the constant splash of diesel oil etc over your boots would rot the fibres !! (and make your sox go off----if you know what I mean ?? ). Don't half make those chromed spanners slippery as well, eh ?? ----OUCH !!!!!!! Wot's that H_O_T thing in the sky ?? Best take the Bullet on the road and find out. Be seeing you ------------------
