By Modern_Day_Rocker - Fri Jul 29, 2022 2:00 am
#102247
Email reply from our host.
"The 200180 cams do give a good spread of power and are different from the 90023 cams, looking at the data on both sets the 200180 cams theoretically are a little milder with slightly less duration on the inlet and lower lift, which will make the low range more useable and have a more stable idle. I think with all the modifications and changes you have made you will just have to fit a set then tune accordingly"
I've ordered a set. I think I should be pretty damn close what I'm chasing.
With my airbox/velocity stack and Mikuni Flat Slide carburettor. That combination really helps throttle response and bottom end signal.
Even wirh the R cams switching from the VM32 round slide to the TM32 flat slide the bottom end performance was night and day with dirt bike fast throttle response.
So here we go again! Stay tuned.
