- Mon Dec 31, 2018 12:22 pm
#9010
Probably a long shot but I need either a post 1950 (Nacelle type) lower yoke or preferable a pre 1950 front end (upper and lower yoke and forks.) I do have a most of the post 1950 front end but the lower yoke looks to be from an early Bullet and the pin has been badly cross threaded, and I have a pre 1950 lower yoke (a bit mangled) and the headlight mounts.
Can anyone help??
I was trying to make the later forks work with the earlier stuff but have since found out the top yoke I have is not model G (it is from the same era) and I cant engineer my way out of not having the earlier screw threaded stanchions without myself questioning the safety aspect of my solution
Can anyone help??
