By mreman
#8677
FOR SALE
ROYAL ENFIELD 500CC BULLET RACE/FAST ROAD CONVERSION.
Re-built by Steve Smith of Midlands Royal Enfield in 2009 specifically for Classic Racing,
this machine has a build cost of approx £8,500 and is ready for racing
or road use with a ‘daylight’ MOT.
The re-build spec includes the following:
ENGINE: Gas Flowed and Ported Cylinder Head, Competition valves/springs, Lightweight rocker units, British con-rod, ‘Alpha’ Roller big-end bearing, German main bearings, up-rated oil pumps,
Amal 932/300 carburettor with trumpet inlet, Appx. 10:1 compression,
Electronic ignition, Powerbox, solid state battery, high performance coil, Megaphone silencer.
CHASSIS; Alloy race tank, Race seat unit, Alloy wheels, Alloy top-yoke, Avon road Rider tyres,
Raised gearing, Competition brake linings, Clip-on handlebars, Alloy front mudguard and stays.
Side stand. rear-set footrests, Race number plates.
Please note that British Historic Racing required the 4 speed Albion gearbox and
Drum front brake for this class of event which are fitted but overhauled and improved.
All Drain and filling plugs are wire-locked as required and there is an oil overflow catch-tank.
The machine has been on track at Anglesey, Cadwell Park and Mallory Park.
It has also been used on the Road.
For appointment to view call Steve Smith 07940 382 483.
Bike at MIDLANDS ROYAL ENFIELD Wem Shropshire uk
Pictures available at www.midlandsroyalenfield.com
£5250.00 ovno
Thanks to Allan Hitchcock for permission to use the website noticeboard.
