- Thu Oct 10, 2013 11:41 am
#2783
Hi All,
This is a readvertisement with price reduction
2004 Enfield Bullet Classic 500cc
Four speed right foot change Kick start, Black with gold striping
Not uk spec; import and Sva.
Front disc brake from new,
Modifications:
PAC removed K&N air filter, Samrat lightweight rockers Uprated oil pumps 18t front sprocket, Boyer points fired electronic ignition Shorter freer flowing silencer Philips bright bulb/ replacement headlight. Replacement indicators, smaller black plastic.
Replaced speedo at c 19000 km (needle fell off original!) New speedo in miles per hour... Total mileage covered is c14500miles
Low speed slip on ice two or three years ago so 2 Small Dents in tank, Replaced clutch lever and mirror, left footrest.
Currently on Dunlop k70 tyres: Front vgc, rear ok prob need replacing in 1k or so.
Service history: regularly serviced Head gasket replaced in first couple of years, Steering head bearings replaced Gearbox repair lay shaft Bush in side was leaking grease, replaced along with new second gear which was found to be chipped One tank bracket (rear double that bolts near seat) broken off.
Full service history - lots of paperwork
Cramster panniers - worn but serviceable Cramster magnetic tank bag (never used ) Cycle speedo fitted MOT to July2014 Tax to June 2014 Runs well but cosmetically only middling, some rust on mudguards, stays and silencer
Much loved but not being ridden enough now, so looking for a good home
Photos available - email [email protected]
Location Oxfordshire near M40.
£1050 Ono (former price £1250)
Modifications:
