- Mon Jul 29, 2013 2:38 pm
#2481
2004 Enfield Bullet Classic 500cc
Four speed right foot change
Kick start, Black with gold striping
Not uk spec; import and Sva
Front disc brake from new
PAC removed
K&N air filter
Samrat lightweight rockers
Uprated oil pumps
18t front sprocket
Boyer points fired electronic ignition
Shorter freer flowing silencer
Philips bright bulb/ replacement headlight
Replacement indicators, smaller black plastic
Replaced speedo at c 19000 km (needle fell off original!)
New speedo in miles per hour...
Total mileage covered is c14500miles
Low speed slip on ice two or three years ago so 2 Small Dents in tank,
Replaced clutch lever and mirror, left footrest.
Currently on Dunlop k70. Front vgc, rear ok prob need replacing in 1k or so.
Service history: regularly serviced
Head gasket replaced in first couple of years
Steering head bearings replaced
Gearbox repair lay shaft Bush in side was leaking grease, replaced along with new second gear which was found to be chipped
One tank bracket (rear double that bolts near seat) broken off
Full service history - lots of paperwork
Cramster panniers - worn but serviceable
Cramster magnetic tank bag (never used )
Cycle speedo fitted
MOT to July2014
Tax to June 2014
Runs well but cosmetically middling, some rust on mudguards, stays and silencer
Much loved but not being ridden enough now, so looking for a good home
Photos available - email [email protected]
location Oxfordshire
£1250 Ono
PAC removed
K&N air filter
Uprated oil pumps
18t front sprocket
Cycle speedo fitted
MOT to July2014
Tax to June 2014
£1250 Ono
