- Sun May 12, 2013 7:04 pm
#2162
i,ve decided to put my much modified electra up for sale, bike is t&t it is much modified ,its got the uprated hitchcocks big end assembly just done 1000miles it has the electra x performance kit by hitchcocks which includes the concentric carb the full bore exhaust pipe 19 tooth gearbox sprocket ,it has hitchcocks electra pushrod adjusters so no jumping off,its had the electric start totally removed not even the hump on the primary casing exists !the toolboxes have been replaced by flat lid type classic triangular items ,the plastic spacer has been removed from the mudguard turning the rear mudguard into a type of bobtail ,it has the minda type switch gear fitted on the left hand side only ,the paint is black & blue ,this bike cost £1000 to overhaul 5 months ago but sadly its not getting usedc as much as it require so will have to go £2000 ovno contact paul via email [email protected]
