By singleminded
#84149
Hi Andy C,
How are those panel lights fixed in place in a garage situation, rather than in a pre-fitted suspended ceiling?
Did you make some brackets?
By Andy C
#84153
singleminded wrote:
Wed Jul 17, 2019 7:38 am
Hi Andy C,
I made a frame to hold them to the ceiling out of some light galvanised steel sections that I got from my local builders merchants - cant remember what the stuff is called but it is just the right size to make an open ended frame (3 sided square) that you can screw to the ceiling and then slide the panel into. Sorry cannot be more specific, it was pure luck that I came across it. I'll try take a pic and upload.
By Andy C
#84197
singleminded wrote:
Thu Jul 18, 2019 7:03 am
Thanks for the info, Andy.
Some pictures would be great!
If the pics upload OK I hope that it helps ypu understand how I mounted the panels. You can also see the mains connection to the LED driver that comes with the panel.
Cheers
By singleminded
#84225
Thanks Andy,
That looks to be within my capabilities.
These units work out so much cheaper than led battens from the likes of Screwfix.
By Andy C
#84228
Allan.
I am sure you will not regret fititng them.
Other benefit is reduced electricity bill :mrgreen:
