- Tue Jul 31, 2012 12:19 am
#916
Bullet MOT'ed today and the first proper ride, (other than the short private road behind the house).
Cruised nicely at 50-55 as several have said on here, I think I saw 65 on the clock at one point but taking it fairly easy on the old tyres which are past their best and not entirely sure as the needle was bouncing around a bit, is that a common thing on the indian bullets?, (i'm no stranger to worn clocks on the old jap bikes and the cheap aftermarket speedos doing it)
Had a nice ride to the garage and back, about 45 miles and popped the plug to check before going for a fill and further ride.
(Standard toolbox air filter assy and silencer, 25 pilot and 90 main with needle on second clip from the top, was middle but colortune showed a rich midrange)
Looked pretty good for mainly midrange running as per pic.
Hopefully getting a shorty silencer soon and converting airbox to the tea caddy unit so a bit more jiggling will be needed then.
Gearbox is fun, may have to look into the mods to the outer case flexing
Next on the to do is the tyres/tubes/tapes, ATF in the primary drive, change the engine oil and filter and fingers crossed for decent weather for some more riding.
