Drain plug
Posted: Sun Feb 10, 2019 10:11 am
by jenks
Where is the engine oil drain plug on 2017 b5 euro 4?
Drain plug
Posted: Sun Feb 10, 2019 11:05 am
by hagis
Your question should be where are the drain PLUGS - There are three all under the engine, one at front, one plate with filter in middle, and one under gear box.
Drain plug
Posted: Sun Feb 10, 2019 9:15 pm
by jenks
Thanks haggis,do you have to remove all of them?
Drain plug
Posted: Sun Feb 10, 2019 9:58 pm
by Haggis
Only if you want all the old oil out!🔧🔧🔧
Drain plug
Posted: Mon Feb 11, 2019 9:10 am
by hagis
Yes, you have to remove all three to get the oil out, and lean the bike to the right to drain oil out of the primary drive side, the plate in the middle has a gauze filter under it so remove this v/carefully, quite fragile, and clean and replace filter carefully.
Drain plug
Posted: Mon Feb 11, 2019 9:23 am
by jenks
Thanks again hagis,I can now carry on with my m aintainance.
Cheers
