By binary
#72845
When you click on "Message Board (All)" and then click on "Social/Other" you will get a long list of forum topics one of which is your "uploading photos". Just keep on scrolling down and on page 3 of forum topics there is one called "photo sharing" and this is all about putting up photos into this forum. A lot of people have used this area to have a try and practise at putting photos up and you could do the same to get the hang of it.
#72848
In "Viewer Links" you will need to select}--- HTML Full linked ------ then you hover your pointer over the big, oblong box at the bottom of the screen when you will see "Copy" appear..Hover your pointer ( now appearing as a hand ) over this word and left-clik your mouse and you should see the big box turn YELLOW for a short while.........This is the well-known Clik and drag procedure so you now return to the Hitchcocks page and "Clik" onto your reply box......All that HTML Code should now appear in your reply box... Clik onto "Post reply" and your photo should appear along with your printed reply .............It reads as quite a lot but it's quite straight forwards really.......
