- Sun Jul 02, 2017 5:35 pm
#7469
I recently changed the oil and filter on my 2015 C5, a job I've done several times since buying it new. After a brief ride it became apparent that there is an oil leak from the filter plate. I therefore took it off again to see if the O ring had become displaced. It hadn't and as far as I can tell the surfaces of the plate itself and the crankcase are fine. I therefore rotated the O ring and put it all back together. Today I went for a ride and it's leaking again. It seems to me that the groove in the filter plate is too wide for the supplied O ring. I should add that all three threads are fine and that I torqued the nuts up to the specified figure both times. My question is whether or not it is permissible to smear the plate with a light coating of silicone. (Having once blocked the rocker supply on an old Norton by using Hylomar I won't use that as it tends to have bits break away). Any thoughts? It just seems weird that this hasn't happened before and I've done nothing differently.
