By vince
#67703
Hi, yes I have one on a 350. It fits with no modifications. You will need the atd although you can run fixed timing on the original pinion. Vince
By mauri
#67706
that will be model 47556
personal i would-end use it with a fixed pinion, a specially on full advance.
you'll won't be starring it with your slippers, cause the eventual kickback will be brutal.
not only for your foot but the oil pump spindle will appreciate it even less.
By simon
#67708
Yep My 350 has one fitted and it has been faultless. Definitely want an ATD with it though. It's very satisfying to put something inside the bump on the timing cover that fits like it was made to go there. It doesnt matter much which SR1 you use asnthey are easily reversible but you do want a flange mount which just goes straight on.
By s1
#67709
Thank you for all your help I really appreciate it I will give it a go and see if we can get her looking like she should many thanks.
