By EddyQ
#6395
How do i upload photographs onto here please.
#59470
Upload to Photobucket, grab html code and paste here. That's one way anyway.
By Leon Novello
#59472
I had this problem when I first started. Keeping it simple. Sign in to Photobucket, it`s free. Then.
1-click on Upload, it will be in the menu along the top, or in a box with` Click to upload` in it. Your pictures album will appear.
2-Select the picture you want. Click on the small box-top right on the picture. It will turn blue with a tick in it.
3-Click `Open` in the box, lower right, it will show file name and upload to Photobucket.
4-Click the box with the tick in it, it will turn blue.
5-Click on `Link `lower-left.
6-Click on the HTML menu, it will turn Amber and show Copied.
Then come here and right- click Paste.
It might be helpful to some instructions in the menu on the left, perhaps below the Photo Gallery.
I am using Windows10, so the procedure might vary a bit.
A photo of my Parents in their courting days, about 1930.
[center]
[/center]
#59502
If you don't use Tinypic or Photobucket you have to write a bit of HTML code as given in Exile's LINK
by way of testing and third attempt today from Flickr
it may or may not work ...
By Exile
#59511
@ Jefrs.. it won't work if you try to hot link from a secure website.. the trick is in the URL, it's a "https" page. It needs to be http only, (no "S")
Your method is OK but you need to be aware of the address... I fiddled with it to get this.. Hope this is the picture you wanted to show..
#59515
Thanks Exile that's the pic but the object of the test was to discover how to do it, not show the pic as such. I understand the "S" but Flickr provides a paragraph of garbage (share "Embed" or "BBS Code"). I'm trying to figure out how much of it I need to chop out. I cannot see the code that I posted, evidently you can because you fixed it. How did you do that and what did you do? - yes I read your LINK. I'm using Firefox but have the usual suspect browsers available. I've done this before and it worked but seem to be having a senior moment. Was it just the "S"?
#59516
Jefrs, you can usually see the code to any image or link (even a broken one) if you "right-click / properties"
