By papasmurf
#6370
In my experience "universal" has meant drill 19 holes yourself, use bits from an old meccano set to make it fit. I have yet to buy a "universal" part that fits with no problems.
By Presto
#59398
The idea of 'universal' fitting I thought isn't so much that it will fit every possible application 'out of the box' but can be fitted to most applications with some, normally slight, modification.
By papasmurf
#59400
Normally slight modification? Not in my experience.
By Reg
#59402
It means it will definitely fit something, somewhere out there in the universe.Who knows, it may even be your bike.
By sofiaspin
#59403
Just bought hosts Amal Mk1, 50s exhaust system and continental seat and all fit perfectly with tiny fiddling needed. I avoid Universal like the proverbial. You get what you pay for etc
By Leon Novello
#59407
Good method to lower the compression and lubricate the upper cylinder.
[center]
[/center]
#59505
Leon - Photo not found but - a little dipping in your bucket - you got a low compression con rod like an early Triumph triple?
