- Sun Apr 17, 2016 1:25 pm
#57727
Yup, new plug on my C5 fixed starting and missing but - The iridium has a tiny pinhead for an electrode. On mine it fouled up rather quickly, because there's only a small area to get dirty and then it cannot get a spark through, so it misses more which fouls the plug and the internals up with soot. Some swear by them, I swear at them. I then tried several of the usual suspects and ended up with the BPR5ES which is a car plug rather than the BPR6ES lawnmower plug. They look a bit different, the 5 looks better made and is about half a step hotter than the 6, both are equivalent to a Bosch 7 (the OEM CGT plug), the 6 is also equivalent to a Bosch 8 (the OEM B5/C5 plug). The oem plugs are weird Bosch-India RE specials not Bosch. A little more heat in the plug may burn the crud off better, if you ride hard you may want a cooler plug but most Bullets aren't ridden like that. Do check the colour but injector reads lighter than a carb does. The R in the legend is resistor so you need a non-suppressor HT cap (my oem metal HT cap fell apart anyway). The oem C5 is a twin electrode and impossible to clean but the CGT 535 plug is normal nose shape. The 535 has opened ports but head, valves and piston crown the same, hence plug clearance is interchangeable. Check HT lead is long enough and not strained, pulling itself out of the HT cap.
