Model G
Posted: Fri Mar 25, 2016 6:57 pm
by Reds
Hi,
I have first refusal on a 1950 model G fully restored 2 owner been in a museam since 2006 , going to collect tomoz , any advice on what to Look for also and what are these bikes like?
Regards Paul
Model G
Posted: Fri Mar 25, 2016 8:34 pm
You've left it a bit late if you're going tomorrow! First off, what are you expecting performance wise? The G is a nice gentle plodder, reasonable performance for a 350, cruise at 50 with about 65 available. Ride is solid, rigid rear might cause jars if you have a bad back. Fuel economy will be good! No real problems with the machine itself, remember this bike was the pre-War 350 Bullet and went on to be one of the better Military machines of WW2 before becoming Enfield's post War second string 350, the ohv Bullet taking top spot. Spares situation is very good at the moment from our Hosts. Original tinware might be difficult though. Areas to look for are same as any old bike, does it start (carb, magneto ok?) and do the lights work (dynamo, regulator)? Does it smoke when running? Do the gears shift ok? Are the wheel bearings/steering head bearings ok? Chain and sprockets ok? Tyres ok? You don't say what price might be, take some pics and show us for further suggestions. Good luck,
Model G
Posted: Fri Mar 25, 2016 8:59 pm
by Reds
Thanks mark price is 4 k it has just been totally restored so hopefully it should be ok the ride I want is just that back lane gemtle plodder , I've had a few bullets 2001 onwards but never a redditch model. If it smoking what this suggests ?
Regards
Model G
Posted: Fri Mar 25, 2016 9:47 pm
Smoking could be worn piston rings or bore or possibly valve guides. A total restoration should not smoke, if it does and the vendor suggests the rings need to bed in, (which is possible,) I'd still be a bit suspicious. £4k sounds like top money to me, I'd want a top bike for that. Model Gs aren't that rare, if you're not happy walk away, another one will be along soon!
Model G
Posted: Fri Mar 25, 2016 10:49 pm
by Reds
Thanks very much for your advice Mark
Regarrds
