ercovered seats and new exhaust
Posted: Tue Jan 19, 2016 10:03 am
by pd110961
just got my seats back from the man.. fully stripped, refoamed, full gel inserts, recovered and detail added. Look great, not had chance to test them. Not cheap at £250 inc postage but that's the coast of quality work. and they turned it round in under a week!
Also.. photo show the very cheap (£30) and cheerfull fishtail exhaust can.. got to be worth a try at that price. first 2 mile run showed the bike pulled well with it and not TOO loud.. I imagine the pipe will be turning a shade of blue soon though!
Posted: Tue Jan 19, 2016 10:04 am
by pd110961
Posted: Tue Jan 19, 2016 12:41 pm
by Exile
To post pictures from 'postimg.org', try using the code "Hotlink for website"..
This forum uses html, not bulletin board text.
Posted: Tue Jan 19, 2016 2:04 pm
by jefrs
Ooh, there's posh. And a blued pipe is a badge of honour.
Posted: Tue Jan 19, 2016 8:20 pm
by Exile
Here's the picture..
Posted: Wed Jan 20, 2016 9:59 am
by pd110961
used it this morning on the 10 mile commute.. the pipre is not blue yet.. but it was rather cold air passing over the pipe.. perhaps they blue easier in the summer?
initial thoughts on the seat..brilliant
Posted: Wed Jan 20, 2016 3:41 pm
I seem to disagree with you all the time jefrs. Sorry, but a blue pipe is a sign of overheating. Usually caused by incorrect mixture or ignition settings. Not a badge of honour in my garage ;-)
Posted: Wed Jan 20, 2016 3:50 pm
by papasmurf
PeteF the only blue on the exhaust pipe of my Electra X (ish) is near the foot rest. Why the pipe gets hot there is a bit of a mystery.
Posted: Wed Jan 20, 2016 4:27 pm
Papa, is it the original? Some of them had a restriction welded in at the bottom end. (supposed to be a sort of catalytic converter I think)
Posted: Wed Jan 20, 2016 11:46 pm
by jefrs
Yes PeteF, the blue colouration is a tempering colour of the chromium running hot, the colour indicates how hot it has got. It is something of a feature of the EFi with a free-flow exhaust. The EFi runs lean to start with and an open exhaust makes it run weaker. Not necessarily harmful to a motor designed to run that way, there's no easy way to enrich it without a PCv. In stock form the O2 sensor should cope with an open pipe, unless you then add the K&N. Exhaust plus K&N plus PCv makes a significant difference to this engine, it doesn't become a fire breathing monster but it does become more enjoyable. The thick walled indian pipe may not discolour but it is restrictive. Mine has fallen back to a light copperish hue since the PCv. A blued exhaust was a sign that you'd given the bike a damn good thrashing, I just had an air leak..
