- Sat May 26, 2012 5:57 pm
#529
Well I've had my Electra x since last october,i'd moved to Spain the year before and thought that an Enfield would be ideal to pop around on, you know, down the bar, beach etc, and really i guess it has down that really well, what with the heat and all. But i've had an annoying rattle. I'm mechanic by trade so set about trying to find it, The bike has a tappet rattle which only appears when it's hot.(not looked at that yet as this other rattle sounded a lot more serious)Anyway i've found it, would you believe it is the filler cap rattling/vibrating on the tank. I only found it by accident when i'd filled it up to the top and it leaked fuel when i was going along. My question is is this common and what can i do about it as nothing seems worn,everthing is tight, it's just a bad fit.
