By malc1091
#4697
Nearly time to awaken HARRYtheENFIELD, have just ordered from our hosts their TCI ignition thingy, any tips on fitting it. Thanks Malc
By papasmurf
#44832
Spring? I would need full Sou-Wester kit to get from my back door to the garage today, and it is only 15 yards away.
By Scalyback
#44833
[center]
Just took this out the window...
Image<
Poor Thunderbolt is going to have to wait...
What I need right now, is a WWII Kettenkrad!
Image<
By wilf
#44836
Hi Malc, is this the Eureka unit? I fitted one recently,it's a doddle. Just follow the instructions. My bike started first kick after fitting and only needed minor adjustment to the timing for the bike to run perfectly. You will find the kill switch won't work any more, but if this bothers you it can be wired slightly differently. Sorry, can't remember exactly how, but no doubt others on this forum willl be able to advise.
#44838
Hey Scaly------ man that's gotta be cold !!..Even the wildlife has frozen solid !! ..LoL !.........Just love those Kettenkrads --imagine going to work on one ?? ( ABRO at Donnington )
By Les
#44842
[center]
Hi Simon one of my boys is a coach driver he has taken a party of skiers to L'alpe d'Huez lots of snow there is that near you
By Les
#44847
As we seem to have successfully hijacked your thread I thought I had best get back to the subject there seems to be a Technical note about electronic ignition, it is in the Technical notes section of this web site may be of use
By Les
#44850
Just looked at it in the accessory shop and my suggestion about the technical note will be of no use I would suggest if you have to extend the wiring to use soldered joints insulated with heat shrink tube rather than crimped or other types of connector
By Scalyback
#44857
Oddly enough the cave paintings of copies of paintings Found in caves.
Sent from my cryphone
