The picture shows the code, the rest of the post IS this pasted code
For one or more new lines, put
see? next line down!
to change text, use All text in this space will appear in colour. Text outside will not be affected.
To do the whole post, including photos, put at the beginning of post,
not forgetting to put at the end, you can visually get the colour value (#XXXXXX) from
http://html-color-codes.info/
there is a whole tutorial, but you only need to click on a
colour and insert the 6 digit number in the code above!
so to get nice text, when you would normally press 'return', jaut insert required number of
for new lines!
Simon
