- Thu Jun 30, 2022 8:07 pm
#101687
as said before, this is a contraversial issue,
just for info, this is how I ran in my classic 500, but I appreciate and understand that the new 350 is a different animal.....
I Read the Owner's Manual and followed the Running In instructions. The maximum speeds given in it I was told by the dealership were a little slow for the EFI-500 . and I went with their recommended speeds in each phase
(0-300 miles) - limit to half throttle, use very gently to 45mph. Stop to let the motor cool down after every hour of riding.
(300-600 miles) - limit to 3/4 throttle and 60mph. Vary the throttle.
(600 miles and beyond) - Avoid prolonged use of full throttle. Turning that around it means occasionally use full throttle. As the engine loosens up, from maybe 1000-1200 miles gradually increase the revs to point of vibration by changing up later and later through the gears i.e. in 3, 4, & 5. In 1st and 2nd it is rather too easy to over-rev. Do not force it through but change up. Work needs to be put into the engine to bed it in so only under power not on the over run by changing down. It is a gradual process not a violent one,
The vibration point gradually moved up the rev band and dissipates.
My engine now runs as sweet as a nut and can hit the rev limiter in top.
I looked at buying used before getting mine but so many seemed to have been 'broken in' vibrated too much and didn't 'feel' right at all, I then test rode one which I knew to have been 'bedded in/run in' with, shall we say 'respect' and it was a world apart from the others, I thought they wanted too much for it given the cost of new so went new.
I think the key to running in any engine and machine is to work it, but not thrash it and keep it in fresh/good oil
