- Fri Sep 07, 2012 7:35 am
#1114
Aragh I'm in trouble with Electrics. I've had a good run with them, been through the full gambit of mechanical problems but it was bound to happen.
I don't know where to start but maybe all this will jog somebodies memory. There's a number of things happening. First off no head light. Neither main beam or dip but when I use the "Flash" switch it does work?
Then there seems to be an issue that sometimes it's not charging and then after riding for a few minutes it'll jump into life and start charging. No headlight whether it's charging or not.
Third when it is charging ever so often, say every 10 seconds, but it ain't regular, the amp meter needle will jump like I've just pressed the horn or something.
I've got a "what do you call it" fitted is it the power box voltage Regulator. it's a few years old at this stage so maybe it's on it's way out. I checked the voltage from the alternator and it's good but that might have been a lucky one and the charge/no charging might still be in there. I'd have to wire up the voltmeter more permanent and mount it.
Any ideas would be gratefully received.
