- Sat Aug 15, 2020 10:43 am
#92152
I took my Himalayan in for it's 3000 mile service yesterday - I was told that you have to have it dealer serviced in the first 2 years in order to keep the 2 year warranty valid.
Anway I was not happy - on the way home I noticed that the idle speed was around 1700 RPM wheras before it was just fine - I have since reset it to 1250 as per the manual.
At home I noticed some oil mist to the rear of the engine which I had never seen before, then I noticed that the oil level was above the top mark in the window, infact the window was full, I drained out 450Ml to bring the oil down to the upper level - could the fact that it was overfilled caused the oil mist.
The chain was also way too tight - you could nearly play a tune on it, now slackened back off.
This was after being serviced by a bona fide Enfield Dealer, trust me once the 2 years is up I shall not be going back, neither am I going to grumble to the dealer as there is still another year to go on the warranty.
Can you trust dealers, or was I just unlucky?
Previous bikes - far too many !!
