- Wed Dec 07, 2016 8:41 am
#64946
There are many, many ways that a motorcyclist can come a cropper but two of the most common I have witnessed are, “in no particular order†(drum roll) ,,,,,,,,,,,,,
Dual carriageway, motorcyclist in lane three gaining on vehicle in lane two. Vehicle in lane two is gaining on another vehicle also in lane two, driver decides to overtake and moves into lane three WITHOUT MAKING PROPER OBSERVATIONS. Consequence, at best biker needs clean underwear, at worst an ambulance. Drivers fault, no doubt about it regardless of speed of vehicles, but the rider can mitigate the consequences by assessing the situation as it develops and taking evasive action like errr slowing down for a few seconds, also by being as HI-VIS as possible.
Urban roads, motorcyclist makes a left turn, forgets to cancel indicators and the impatient car driver waiting to turn out of the next junction believes the signal and pulls out. Consequences as above. This situation has far less to do with HI-VIS but the rider can take steps to reduce the risk.
I have fitted a device that gives an audible warning in addition to the warning light in the speedo head, readily available on an auction site for about £10 delivered. It came with a buzzer that when mounted on the handlebar gave about 85 Db at my head position which I replaced with a shriller siren that measures 100 Db when mounted inside the headlight housing. I can hear it while accelerating with visor down, balaclava on and hearing aids in pocket. It is also wired in such a way that when the brake light is on the siren is off. This means that when you release your brake to make your turn the siren kicks in and gives you a reminder to cancel the signal. Makes a lot of pedestrians’ heads turn as well.
I will employ anything that helps keeps me safe.
At all times treat every other road user as your potential assassin. Stay visible, stay alert, keep all eyes open, especially the ones in your ar5e.
Adam
(Hope the paragraphs work)
