- Sat Aug 22, 2020 7:11 pm
#92385
Physics 101 - weight hinders acceleration
Alloy stays can weigh the same as steel but will be much stiffer. We discovered this last century.
Reading some of the responses, it's glaringly obvious why we no longer have a motor industry
If you need explanations as to why weight is bad, I'm not going to waste my time trying to pull you away from polishing your brass. Read.
Exhaust lagging is basically fibreglass - not renowned for being heavy. Go and google why it's good.
I looked at swapping the rims/spokes with aluminium/stainless but it's over £300 a wheel. I'm looking at other bikes to see what is suitable but the sprocket alignment is an issue.
Rear has been junked - saved 3kg with the replacement. Saved half a kilo by changing those.
I'm planning on a new seat, I've never made a seat be before so it should be fun. I'll get it professionally covered. I've already started with titanium
Yeah, it won't have much more speed than another Enfield but it will out-accelerate and be more economical.
No wonder we no longer have a motor industry
