By Simon D
#64331
Just checked the service manual and it appears 30 is a bit out.....It reports that the front should be 26 psi for solo and duel riding whilst the rear 28 solo & 32 duel....Ah the power of reading..
By Revband
#64332
Ah the power of reading, I always find it best to know the answer to a question rather than passing on second hand info, ;-)
By abe
#64334
Cheers all.
i have set me digital pump thinghy to 30psi now so now i just switch it on,and thats it.
im no lightweight so a cross between solo and 2 up lol.
does the car and lawnmower as well.
ps,
getting through the loctite as the miles stack up.
By Scalyback
#64335
My brother Phil lives in Reading, and he agrees about 29-30 front and back.
He also suggests carrying your own pressure gauge that you know is correct. Use the gauge at your local garage, but then check with yours every so often to check that the garage are calibrating it correctly.
I guess that is the power of Reading?
