By Leon Novello
#49724
The Latin phrase, verbum satienti satis est, was posted in the last post between V`s on their side, but didn`t appear in the post. Is this because the board doesn`t accept mathematics symbols?
By Scalyback
#49725
not quite... If you put 'v' on their sides, the software thinks it is an HTML command same as the brackets for bold text.
who want to correct my latin? I not vwey good at it. ubi amor ibi fides
By Leon Novello
#49726
Hi Scaly: In your 9.36 post before mine, you have vees on their side on each side of the . Why is it so? I have put vees on their side each side of the B on here, let`s see what happens this time.
By Chris [Stockport]
#49730
Ok, I'm supposed to be doing jobs in the house , but this won't take a minute, will it? -Chris
#49738
Just having a go at this
and another
Scaly, how do you get green? Or any colour for that matter?
By Les
#49739
before text for colour
Delete the replace this with code in the line above and replace with your own colour code
Some colour codes Here
By Les
#49740
Try again
round the wrong way so it appears you will need to reverse it
By Les
#49741
Nuts try
p style="color:#replace with colour code here"
I have taken the < and > off each end so it can be seen I hope you will need to add them
By Les
#49742
If you right click the page and select view source you can read the code but it is a bit of a strain on the brain
