- Thu May 29, 2014 10:46 am
#36312
I checked on the net just to make sure my recollections were correct...
Enamel paint is paint that air dries to a hard, usually glossy, finish, used for coating surfaces that are outdoors or otherwise subject to hard wear or variations in temperature.
Uses and categories of enamel paint
Floor enamel – May be used for concrete, stairs, basements, porches, and patios.
Fast dry enamel – Can dry within 10–15 minutes of application. Ideal for refrigerators, counters, and other industrial finishes.
High-temp enamel – May be used for engines, brakes, exhaust, and BBQs.
Enamel paint is also used on wood to make it resistant to the elements via the waterproofing and rotproofing properties of enamel. Generally, treated surfaces last much longer and are much more resistant to wear than untreated surfaces.
Model building - This paint is usually sold in 14 ml tinlets (in the UK) and is available through specialist hobbyshops. Xtracolor and Humbrol are well known UK brands that have a wide range of colours, covering most of the ones used by various armed forces. Testors, a US company, offers the Floquil brand for railroad models, and Pactra, Model Master and Testors brands for aircraft and car models. Liquid enamels are sold in 1/4 to 1 oz. bottles, and some colours are also available in spray cans.
REOC 15084
Tabellarius de verbis. Ostensor gaudium
