By Barry_Q
#26520
As I've said, my clutch is just fine and I've never had a problem with it. I fitted one of our hosts roller bearing pads very early on. I find the clutch easy to operate and I've never had any slippage. Mind you, I did have a bit of drag before I fitted the roller bearing pad. Fitting the outer cover stiffener has made gear changers more positive. I do find the gear lever is about an inch too long, but I've gotton used to it. Mind you, I think the gearbox is a bad design, The neutral finder was a solution to a bad clutch.
#26521
Barry, as you said the neutral finder helps but if there is the slightest drag on the clutch the neutral finder will give trouble it will put it into first or won't work at all because you still have load on the gears
