- Sat Sep 26, 2020 1:48 pm
#93227
Got them yesterday, fitted them today. Someone had already mentioned the fact they don’t line up.... really? Check the first two pictures... the back fittings lined up very well.... let’s look at the front two!....
Anyway, as you’ll notice, the rear bottom bracket is a good inch and a quarter plus from the holes. And rather than drill new holes through the provided number plate reinforcement plate, I’ll left it as is.
I’m happy. With one fitting they wouldn’t come off the bike. The two front ones are substantial and there’s still the back top ones on either side. The non bolted fitting is tight to the back, I can see it causing sone chafing with panniers fitted and travelling, I’ll just monitor it, it is definitely secure.
As I have a rack fitted, the original top suspension mount bolts were too short. I fitted a spacer between the rack and pannier holes for the bolt to go through. I had to drop the rear subframe to get the bolts out, so took the opportunity to fit new bolts from the outside in. A much better idea for future removal of the bolts without having to drop the sub frame.
Blooming pictures! I just deleted them and rotated! I give up
