- Mon Oct 03, 2016 10:18 am
#63014
I kinda agree with Rattlebattle but having fitted the PCV, I would not swap it for a carb now. The carb conversion kit was not available at the time. Fitting the PCV is kinda simple, it just plugs straight in, understanding pages of number is perhaps not. The PCV does however also control the ignition A/R which you lose with the carb conversion. Fitting the PCV is simplicity, but it does have to be enabled, which means waving a laptop at it. And it has to be mapped, which means Hitchcocks maps because they're the only company with RE-specific maps (Ok so Dynojet have one but it's like don't bother). Fitting a carb requires several drastic changes to the engine/management.
If you have swapped out the stock "towing a log" silencer you will have noticed just how heavy it is, quite apart from being pug-ugly. From there is an easy step to swap out the air filter for a better one. You can change the silencer on the ECU and it will cope with that but once you change the entire exhaust system and the air filter it can't and we need to do something else because the air/fuel mix has gone to pot. Even though the ECU is mapped to over 18,000-ft, it is designed for very poor fuel; we have an 'export' ECU, it is not the same as the 'domestic' indian ECU. The stock ECU does not allow user-tinkering, nanny rules, the PCV does.
I could have got any bike I liked. I wanted a bike to potter around country lanes without wrestling with it. I have short legs, so it had to fit me and I dislike very heavy bikes. I had a hankering to relive my long-ago 350 but in reliable format. I like tinkering with bikes but did not want to have repair or rebuild an old bike.
