Wheaters wrote: ↑Sun Sep 29, 2019 8:42 am
It might be an issue with the cush drive rubbers in the hub
No, it was clanking before I changed the rubbers.
I stripped the rear wheel, changed the bearings in the hub and the drum, changed the cush rubbers, checked the bolts for the cam mounting, checked the nut on the post. I lubricated everything with a dab of copper grease, assembled all carefully, nothing leaning or rubbing on anything else, AND IT'S STILL DOING IT!!!
Hopefully I'll pull it apart this afternoon again and get to the bottom of it.
