By mauri
#85783
Boxerman wrote:
Sat Sep 28, 2019 7:23 am
Are either of you following Michael Waller on youtube? he is creating a replica trials 350. He's using the later frame though.
This episode features footrest mounting: https://www.youtube.com/watch?v=vfWlnHbJdno
Frank
you'll be beter of folowing this guy
https://www.youtube.com/watch?v=zsY-jR8oFdE
at least it doesnt take him ten episode to put a brake pedal on, which he will have to redo ones he figered out what hes done.
hint--> leave putting on the side stand to very last
By Boxerman
#85791
mauri wrote:
Mon Sep 30, 2019 10:42 am
I do not wish to learn anything off someone who works knee deep in his own rubbish thank you.
I didn't watch the vid you linked to, I switched off as soon as I saw who it was because I've watched a couple of his in the past. That was enough to put me off any more he has made.
I have followed Michael for quite a long time now, his videos are well presented and I like his style and his humour.
Frank
Though I'd dig this up again.
I've gone with the pillion pegs for just now on the basis that it cost me nothing but time, paint and some fasteners to get them cleaned up and involves no fundamental alterations to the bike. If it all works, I'll probably bolt on a pair of the "bear-trap" type trial pegs to the mounts.
WIth the pillion pegs flipped and swapped, I had a good old bounce on the bike and they didn't move. I don't think they will unless I land hard enough to bottom everything out. Even if they do slip, it'll only be pivoting down a couple of inches, I'd need to stop and move them back again but nothing that's going to cause an accident.
I just got the brake lever sorted out. Looks a tad sketchy because I based it on cardboard templates and cut/machined it freehand but I'm pleased with the overall functionality and better, it bolts straight onto the original pivot.
Off the shelf clevis joint.
The bit of flat bar trapped under the locknut is to butt against the original "stop" so it doesn't over-rotate backwards.
All in place.
