- Wed Sep 25, 2019 10:35 pm
#85599
Hi Everyone,
I have a motogadget classic tachometer that I want to connect to my RE GT 535. I note that the original OEM tacho has two inputs that come from the crank sensor. Neither of these will connect to the Motogadget gauge which only requires one input.
The motogadget manual states this:
leads to the ignition coil, terminal 1
(switched ground of ignition unit)
In case of a CDI ignition, please use the
motogadget ignition signal sensor (order no.
9000001)
Where should I connect the gauge to on the ignition?
Thanks.
9000001)
Thanks.
