By vic
#96
hi all
its my first time on this message board so be gentle with me
i have been building my indian 350 2004 bullet for about 3 years now (on and off )
ime trying to convert the hi beam /and indicator on the speedo dial to led hi beam is ok
but the indicator will only flash on one way the two wires that feed the old bulb is green and black  the other is black and white
if i connect the old bulb up this flashes normal
any help would be gratefully accepted
is the answer to fit two green led lights one for left and one for right
regards
vic
By Paul M H
#9921
LEDs are polarized you will need two leds one each side in correct polarity.
#9927
 Vic,
      LED's give you problems, as said aboveI had to fit one for each side and also for some reason I had to wire in an extra bulb holder and run a standard globe in it , just laying inside the casquete to get one side to operate. I fitted the 6 led indicator lights on each side of the casquete because they are very bright and catch your attention, but at night they are so bright I can hardly see where I'm going when turning
By vic
#10334
help please
many thanks for your help paul mh  and norm
about green led indicator light in speedo
i found out that only one led is required as if you take the
two wires from flash unit to the pos and neg of led it works
ok opporsite of indicators thanks
i
By vic
#10335
breather pipe
hi all i have removed old air filter and housing bought an amal
26mm mono block what do i do with breather pipe from engine
and the one from black pot
regards vic
