- Fri Aug 30, 2019 7:57 am
#85154
hi all,
I have just bought a C5 which runs nicely , but I noticed a strange screw in the throttle stop location. Not the usual screw with lock nut.
this probably means that someone has fiddled here!!! which they shouldn't have !!
I would like to check this setting and the butterfly gap to body in the venturi if anyone has this gap please.(it is often about .002" measured with a bit of flattened solder on cars).
I can then do the voltage settings after to put everything back to basics.
it has the Gold Star silencer on it , so may be runs a little weak ,
thank you
thank you
