Whining in the primary drive case.
Posted: Sat Aug 24, 2019 5:09 pm
by Al Crusader
Its the Crusader 250 again. Running well but a good whining in the primary case. I am assuming this is a tight chain? Do they make those noises?
Re: Whining in the primary drive case.
Posted: Sat Aug 24, 2019 7:02 pm
by Chris Tindal
Yes, well bullets do. On the odd occasion when I’ve set my tensioner too tight there’s been a very audible wine.
Posted: Sat Aug 24, 2019 8:19 pm
by Al Crusader
That's reassuring Chris. Thanks. Off with the chain case again!
Posted: Mon Aug 26, 2019 11:46 am
by stinkwheel
On my bullet, if you listen carefully, you can also make out a slight whirring/whine from the alternator, which gets louder when you put the lights on. If the gap between the rotor and stator isn't set correctly, it gets much more noticeable, to the point of being intrusive.
Posted: Mon Aug 26, 2019 5:33 pm
by OldBoy67
Not normal, although I'm surprised you can hear anything above the racket the valve train makes!
Did you find anything when you took the primary cover off?
