On my bullet, if you listen carefully, you can also make out a slight whirring/whine from the alternator, which gets louder when you put the lights on. If the gap between the rotor and stator isn't set correctly, it gets much more noticeable, to the point of being intrusive.
By OldBoy67
#85100
Not normal, although I'm surprised you can hear anything above the racket the valve train makes!
Did you find anything when you took the primary cover off?
