- Thu Aug 09, 2012 12:29 am
#964
DUFFEL WITH ANOTHER QUERY THAT'S PUZZLED ME FOR YEARS WHEN ADJUSTING CHAINS YOU ALWAYS CHECK AND ADJUST AT THE TIGHT SPOT OWING TO WEAR IN CHAINS AND SPROCKETS ETC I HAVE JUST RENEWED THE REAR CHAIN WITH A GOOD MAKE PUT A NEW GEAR BOX SPROCKET ON ENGLISH MADE SUPPLIED BY OUR HOST WHO ALSO SUPPLIED AN EXCHANGED BRAKE DRUM/SPROCKET WHICH HAS HAD THE OLD SPROCKET TEETH MACHINED OFF AND A NEW BOLT ON SPROCKET. WITH THE NEW CHAIN AND SPROCKETS FITTED I WOULD HAVE THOUGHT THAT THERE WILL BE VERY LITTLE DIFFERENCES IN THE TENSION ALL ROUND BUT THERE ARE TWO PLACES IN THE CHAIN THAT HAS A TIGHT SPOT AND WHEN THESE ARE SET CORRECT THE REST OF THE CHAIN IS TOO SLACK ?
