#84484
Hi folks first ride to mot centre on my recently acquired Enfield which it passed happy days. . I runs fine apart from a clatter which is annoying it quietens down when you throttle off. Any suggestions please.
#84492
Check the primary chain, if it needs tightening the adjuster bolt head can clatter against the outer primary case. Also you might have a bit of rattle from the cam gears, the spindles on the Electra-X are adjustable to take up some of the slack.
Well I have sorted the clatter from my electra x 500, the thrust slave washer had gone so was causing play in the inlet cam/ rocker. Both have been replaced and the bike is running sweet now. Once again I would like to say thanks to all for their advice and support it has been very much appreciated indeed. Happy biking and ride safe
