Needle jet removal?
Posted: Tue Aug 07, 2012 9:36 pm
by Jack
Hello,i have to remove the needle jet (micarb 28mm)but it won't clear the final 1/4",is there a pin stopping it or does it need forcing?Jack.
Needle jet removal?
Posted: Tue Aug 07, 2012 11:29 pm
by Riggers
Hey Jack - If you look on this site under 'Technical Notes' - see options on the left - and check out 'Tuning and using Mikarb' you may find a solution to your problem. If not DON'T use force, post again on this thread and we'll try to help. Lots of us know the Mikarb inside out.
Needle jet removal?
Posted: Tue Aug 07, 2012 11:33 pm
------------------unfortunately !!
Needle jet removal?
Posted: Wed Aug 08, 2012 9:36 pm
by Jack
perhaps i shouldn't have used the term force then,maybe a tap with a punch would push it through,possibly it's only got some gum on it.
Jack.
Needle jet removal?
Posted: Wed Aug 08, 2012 11:12 pm
by Riggers
Hey Jack, if you've already unscrewed the main jet, and secured the washer, the pilot jet should be removable from the other end of the carb without a problem. No force - just pursuation! Nothing should stop its removal, but if it's a tight fit just be very gentle with a soft drift.
Needle jet removal?
Posted: Thu Aug 09, 2012 12:23 am
---------might I just add to that " ensuring that it is perfectly vertical". I have 2 of these delightful little rascal carbs.---on one the needle jet just drops out, on the other it requires just a little gentle help.
Needle jet removal?
Posted: Thu Aug 09, 2012 1:50 am
by Jack
Hey guys,solved the problem,it did only require a push to help it along.And i fixed the persistent flat,stall spot while taking off from the lights.Fitted a P2 needle jet in place of the O8 and float level 23mm instead of 25mm.
No hesitation at all now.I'd replaced the 25 pilot with a 27.5 then 30,they helped but she'd still die unexpectedly at the lights unless throttle as eased in very slowly,not something i enjoyed.
So all's well in Bulletland.
Jack
Needle jet removal?
Posted: Thu Aug 09, 2012 10:06 am
------------until the next time !! But don't you just love 'em ?? We're off into Wales this evening (Lake Vyrnwy ) for a Fish & Chip Supper-by-Sunset. Nice one Jack---now go and ENJOY !!!!
Needle jet removal?
Posted: Thu Aug 09, 2012 12:25 pm
by Riggers
Well done Jack, nice one. Mine's haddock and chips please Alan. ;-))
