- Wed Jul 17, 2019 4:11 pm
#84162
Hi Eric yes compression is good as far as I can tell have taken carb of to check jets etc.
I will look into that Adrian for sure thanks for the heads up on that.Adrian wrote:Glad it was easily fixed.
If a used set doesn't show up, Watsonian-Squire must have some. Besides their sidecar manufacturing, they were the Royal Enfield importers at the time of the Electra-X models, and I believe they fitted quite a few Electra-X and other Bullet models with sidecars.
Do you plan to lower the gearing for sidecar use? The standard 18T gearbox sprocket leaves it a little over-geared for solo use, never mind lugging a sidecar around. 16T will give you a 5.3 to 1 overall gearing in top.
Thanks Chris yet again something I wasn't aware off. DChris [Stockport] wrote: ↑Sun Jul 21, 2019 7:40 pmHave you got a back tyre ready for the front?
-Chris
