- Tue Jul 30, 2019 1:17 am
#84417
Iwent up one tooth, easy job, good access, chain was stretched
d enough to accommodate the larger sprocket. I can carry all the gears to a higher road speed (less shifting) rowing through the gearbox in traffic is no fun and this reduces the need. 4200 revs at seventy mph. Much more than that and the pigs will be lining up to loot you! well into the powerband and 53 mpg with the alcohol infested gas here in USSA.
