- Sat Jun 29, 2019 7:09 am
#83797
I have had my Interceptor for 4 months and done just over 5000km. Since new it has had an intermittent grating feeling when pulling in the clutch. The same feeling as we used to get when a strand of inner cable was broken or the nipple or cable was not lubricated. I have told the dealer but they can't replicate it. It mainly happens when changing down. In the end I bought a new clutch cable, noting that 8 inches from the gearbox end there was a bit of a kink as the cable takes a sharp bend to go through the 2 clips on the frame. The new cable made no difference to the fault. I then ran the cable not using the clips and cable-tied it to the oil cooler to keep it off the exhaust. Still had the original fault BUT the clutch is much lighter to pull in as it takes a nice curve now. I suspect the trouble is in the gear shift mechanism and all I can do is wait for it to break so it can be fixed under warranty. Sometimes it is hard to change down (the gear lever does not seem to latch) and on three occasions the neutral light has told me a lie when I pull up and release the clutch only to jump forward in gear and stall. If you have a 650 can you check the routing of your clutch cable and tell me if it goes through one or both of those clips.
