Interceptor Mk1 mag drive removal
Posted: Mon Jun 24, 2019 10:59 am
by gak
Trying to remove my 62 Interceptor magneto for repair. Best way to remove the mag drive cog to facilitate its removal?
Re: Interceptor Mk1 mag drive removal
Posted: Tue Jun 25, 2019 3:37 pm
by Lou E
Remove timing cover/ undo the nut in the center of the mag sprocket/keep unscrewing as this acts as a jackscrew against the end of the maneto armature shaft, and pulls the sprocket off the taper.....
Posted: Wed Jun 26, 2019 4:41 am
by gak
Thanks Lou
The nut is off the shaft, the mag sprocket has not come off the shaft with the nut.
Posted: Thu Jun 27, 2019 4:26 pm
by vince
Hi, the self extractor are on A/R sprockets. If you have a manual advance ,the sprocket should have a internal thread for an extractor. Alternatively give the sprocket a light tap with a hammer it may come off depending how tight the tapered fit is! Vince
Posted: Thu Jun 27, 2019 10:40 pm
by gak
Thanks Vince
Yes that is what the sprocket looks like. By any chance do you know what the sprocket's internal thread is as I've tapped and used a puller without effect. Geoff
Posted: Fri Jun 28, 2019 12:22 am
by Lou E
good point my mag is a K2F with auto adxance
Posted: Fri Jun 28, 2019 8:04 am
by vince
Hi, I think the extractor is the same as that for a bullet, if I can find my spare sprocket I'll check. Vince. Ps did you give the puller a thwack to shock the taper?
Posted: Tue Jul 02, 2019 3:05 am
by Lou E
If gently smacking the puller while it is under pressure does'nt do it try heating up the sprocket with a propane torch then smack the sprocket
Posted: Tue Jul 02, 2019 4:00 am
by gak
Thanks Lou E
Plan for tonight - will let you know. Puller, tapping and heat. Geoff
Posted: Mon Jul 08, 2019 8:55 pm
by gak
Eventually had to make a tool to release the sprocket. Internal thread of the sprocket is 5/8 BSC if anybody is interested. Mag away for repair.
Thanks for those who replied. Geoff
